Loading [MathJax]/extensions/Safe.js
Author Topic: DC/DC 48V/60V to 12V-10A  (Read 20174 times)
Offline sangseuTopic starter
  • Country: vn
« on: June 19, 2017, 11:58:34 am »
Hello everybody. I'm study DC/DC converter. I've teardown a "DC/DC 48V/60V to 12V-10A" product and wana copy that.
I've draw schematic
and trouble with a Trace has mark in picture
Is That Trace a Shunt or some things else ? Could anybody explain it for me ? Please.
Offline fourtytwo42
  • Interested in all things green/ECO NOT political
Re: DC/DC 48V/60V to 12V-10A
« Reply #1 on: June 19, 2017, 12:23:53 pm »
I see several problems with the schematic, I assume Q1 is N-channel ? well if it is the integral diode is drawn the wrong way around. The trace you ask about is a current sensing shunt, if you want to copy this pcb then make sure you copy that traces dimensions exactly (weight, width & length).
The following users thanked this post: sangseu
  • Country: vn
« Reply #2 on: June 19, 2017, 12:42:07 pm »
Yes, MOSFET is N-Chanel. If I can measure resistor of that Trace, I can replace it by a Shunt Resistor, don't I ?
Offline MagicSmoker
« Reply #3 on: June 19, 2017, 03:44:20 pm »
The MOSFET is drawn correctly, but this circuit won't work for a number of reasons.
The first is that you need some kind of floating or charge-pumped supply for driving an n-channel MOSFET in a buck converter, as the gate needs to be brought 10V higher than the source to turn it on, but the source will be at the same potential as the drain at that point... (there are alternative approaches which I am omitting in the interest of brevity and simplicity).
Next is that the current sense signal needs to be obtained with a differential amplifier or some other high-side sensing scheme because the Isense input on the PWM controller IC expects to see ~1V with respect to ground.
Using a trace for the current sense resistor is a time-honored hack for doing things very cheaply while also getting a degree of temperature-dependent overload protection for free - the resistance of copper goes up 0.4%/C. But, as I said already, you need more circuitry to do this in a buck converter in the first place.
Offline bktemp
« Reply #4 on: June 19, 2017, 04:16:57 pm »
The circuit is correct and will work. The UC384x operates as a floating highside switch driver:
D2 is the bootstrap supply using the 12V output voltage. R4 is the startup resistor.
The current sense is also correct, since UC384x GND is connected to the switching node.
Offline MagicSmoker
« Reply #5 on: June 19, 2017, 04:26:27 pm »
You are correct - I should have noticed that the node labeled Gnd wasn't connected to the 0V common line between input and output.
Carry on!
Offline fourtytwo42
« Reply #6 on: June 19, 2017, 07:12:42 pm »
Hmm the picture is so poor I had thought the diode cathode was connected to the source but perhaps its the drain after all :)
Offline fourtytwo42
« Reply #7 on: June 19, 2017, 07:14:35 pm »
You should not have to measure it, according to the schematic it's 0R2 or is that your estimate ?
  • Country: vn
« Reply #8 on: June 20, 2017, 01:13:36 am »
It's my estimated. take some math, V_ref = 5V, I_sense about 1V, resistor devider is R2---R3-R_Shunt so U_Shunt ~ 0,24V.
I_in ~ P_out/U_in = 1,7A so R_Shunt ~ 0,24/1,7 = 0,14 Ohm.
Right, this schematic may work follow this INVENTION
https://www.google.com/patents/US6313616
I can do that by import picture of that PCB to KiCad and make the same Trace Shunt. But, different PCB quality causce different value of Trace Shunt.
Please give me a suggestion for copy that designed.
« Last Edit: June 20, 2017, 01:27:03 am by sangseu »
