Author Topic: Stepper Motor Control – Arduino For Beginners  (Read 2006 times)
Offline mahendaran RTopic starter
« on: November 22, 2014, 07:33:46 am »
I have done a program for arduino to rotate stepper motor in clockwise and anticlockwise….in that stepper motor was  initially vibrating…..i have an doubt …whether I  done a mistake in my program or circuit….
http://www.ingenstech.com/20-stepper-motor-control-arduino-beginners/
Offline rob77
  • Country: sk
Re: Stepper Motor Control – Arduino For Beginners
« Reply #1 on: November 22, 2014, 12:09:37 pm »
if a stepper is just vibrating instead of turning, then either you have swapped coils or the control is wrong ;)
Offline Rerouter
« Reply #2 on: November 22, 2014, 08:46:55 pm »
In there example they are using a driver IC to buffer the signals from the arduino, are you using a chip like this, or trying to directly drive from the arduino?
to reverse direction on most 6 wire steppers, you reverse the 2 outer wires for one coil, vibrating could be one wire from each coil is flipped
« Reply #3 on: November 24, 2014, 05:39:13 am »
thanks for the suggestions will see to it ...
Offline Kappes Buur
« Reply #4 on: November 24, 2014, 05:47:22 am »
With a board like this, it is really easy to drive a stepper motor.
