As i have mentioned elsewhere i was making a fuel injector pulser based around an
IRFZ34N and today i gave it a full test and it fried, d'oh.
The connected load was 4, 3.5 ohm injectors in parallel, powered from a car battery with 13V.
From the mosfet datasheet it says that the Rds is 0.04ohms which should mean only a tiny amount of power being dissipated (around 8W) so i hadn't even considered a heatsink or anything
It worked for a while, 30-45 seconds than let out the magic smoke without any pop bang or fizz and the mosfet is now short circuited.
I was using a suitable flyback diode across the load
Everything else in the circuit works fine still
Any ideas where i've gone wrong?
(Schematic coming as soon as i figure out how to make one)
Chet
