Author Topic: Current Shunt  (Read 15692 times)
Offline zapta
Re: Current Shunt
« Reply #25 on: May 02, 2014, 12:54:28 pm »
.. I'm not sure about the LTC1943, typo maybe?
Yes,I meant ltc2943 (there are also many others).  High side has the advantage in some applications because  you can share ground but is more difficult to implement unless if you use one of these ICs.
Sent from my Nexus 5 using Tapatalk
