I'm building a 3d printer with dual extruders and two separate fans. Both are run to the same 12v pmw pins on the ramps Arduino board. However, I'd like to wire a "thermal switch" inline with the 2nd fan. This switch would turn on when the thermistor on the 2nd hotend exceeds ~100°c roughly.
Questions:
Could I use the thermistor that's used on the hotend as the temp sensor?
What logic ICS or something else would I need to buy to turn on above a certain temp?
How would the min temp be set? Resistors/capacitors?
Any rough sketch of a circuit would help and be greatly appreciated.
I can attempt to mock something up in eaglecad or another ecad tool if that helps.
