Author Topic: current sense led circuit  (Read 3992 times)
Offline FlumpTopic starter
« on: June 01, 2015, 11:34:43 pm »
can anyone suggest a way of making a led light up when current drawn by a device drops below 300mA ?
it is for a ocxo, when the heaters on it draws 400mA but when its up to temp it settles to about 250mA
i would like visual confirmation of that.
an example circuit to look at would be great if anyone has something like it.
Offline V8Snail
Re: current sense led circuit
« Reply #1 on: June 01, 2015, 11:58:25 pm »
Do you have a link to the model of OCXO you are using?
« Last Edit: June 03, 2015, 10:50:21 pm by V8Snail »
« Reply #2 on: June 02, 2015, 12:41:24 am »
Offline TerminalJack505
« Reply #3 on: June 02, 2015, 02:03:02 am »
Here's one way to do it.  Assuming that you can put a resistor between the heater and ground, that is.
Offline V8Snail
« Reply #4 on: June 02, 2015, 04:40:03 am »
This is along the lines I was thinking, except instead having just the heater monitored, which looks to be impractical with this package, connect pin 4 and GND of the 8663 package between VCC and R1 of this circuit.
Bear in mind, the unit he referred to is 12V not 5V, but this is a good way to ensure the voltage drop across the current sense resistor stays well within the required 5% of 12V VCC.
« Reply #5 on: June 02, 2015, 12:56:39 pm »
Whoops.  I didn't look at the OCX's datasheet before drawing the schematic.
It might be better to monitor the current from the high-side.  This way the sense resistor doesn't affect Vref.  That would be a little trickier.
« Reply #6 on: June 03, 2015, 01:41:58 am »
Here are a couple of circuits that should work for sensing the current from the high-side.
One uses an INA138 high-side current monitor IC.
The other uses more jellybean parts.  The P-channel MOSFET shown in the circuit can be pretty much any part.
Offline rx8pilot
« Reply #7 on: June 03, 2015, 02:21:57 am »
I think there may be some of the INA current sense amplifiers with fault outputs. Could have a lower part count. Set it to reverse indicate anything over 300ma or whatever threshold you need.
« Reply #8 on: June 05, 2015, 07:36:09 am »
thank you all for the advise  :-+
