Dear Members,
I am doing project goal is to get the analog output voltage from the optical current sensor as a input data to the raspberry pi 3.
Please find the sensor external overview circuit where you can find the IMX2 D SUB 9 female pin (analog output).
Can I use USB to RS 232/RS 422/ RS 485 Adapters which are available in the market as transmission channel from sensor IMX2 D SUB 9 to raspberry pi 3 via USB outlet.?
If yes, What kind of drivers needed and do we have any example program code for this kind of system.
Thank you
Sairam
