P.S. another way to move a 3 phase motor would be using RC equipment like many people has suggested before. Get a cheap ESC (electronic speed control) for a 3 phase motor, a compatible motor and a servo tester. Servos receive signals from the RC receiver the same way an ESC does, so by getting a servo tester, the ESC will "see" that it was pugged int to a receiver. You can even control the speed with the tester. You can also make your own if you want to have some fun.
This seems to be the most simple way to get this project working. Since these have be obviously designed for small motors, i wonder how well, if at all, they will work for one with an approximate diameter of 15 centimetres. Though looking at the specs of these ESCs, they should output a decent enough current though I am worry if this would trip the power supply's safety to cut at 5A. I can see a problem when it is furst turnt on but when the motor is actually moving this should more be an issue.
Plus this is an induction motor and not the standard found in RC motors which contain magnets.
Time wise, we have about a month to do this, so I might have to go on a whim and just buy it and see if it works or not. If not, then onto the next idea.
