Author Topic: Cannot load DSLogic (dreamsourcelab-dslogic) driver in PulseView  (Read 435 times)
Offline ArvidTopic starter
Hello,
I have problems with PulseView an DSLogic on Linux!
I checked the driver with:
sigrok-cli --driver dreamsourcelab-dslogic  --scan:
The following devices were found:
dreamsourcelab-dslogic:conn=1.8 - DreamSourceLab DSLogic Pro with 16 channels: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
But when I choose the driver in the 'Connect to device' window, it found no device if I scan it!
The LED of the DSLogic is orange!
I get the following errors in the log:
srd: Failed to load decoder gpib: missing or malformed 'tags' attribute
srd: Failed to load decoder iec: missing or malformed 'tags' attribute
dreamsourcelab-dslogic: Failed to open potential device with VID:PID 2a0e:0003: LIBUSB_ERROR_ACCESS.
The lsusb command gets:
Bus 001 Device 008: ID 2a0e:0003 Shenzhen DreamSource Technology Co., Ltd. USB-based Instrument
With Windows (10) it worked!
I think it's not really a PulseView issue, but I'm hoping someone can help me.
Offline madires
  • A qualified hobbyist ;)
Re: Cannot load DSLogic (dreamsourcelab-dslogic) driver in PulseView
« Reply #1 on: May 09, 2024, 03:26:56 pm »
Looks like a quite old version (gpib and iec are replaced by ieee488). I think you can ignore that.
That should be the cause, i.e. access rights. Most likely the user running PulseView has no access to the device. The best approach is to add a udev rule for the DSLogic Pro to set a specfic group (/etc/udev/rules.d/99-local.rules), and also add the user to that group (/etc/group).
Online tatel
« Reply #2 on: May 09, 2024, 05:13:57 pm »
Use DSView, not PulseView. There's bad blood between the guys at Sigrok and DSLabs. So the support in PulseView for DSLab products isn't the best.
Download DSView: https://www.dreamsourcelab.com/download/
Video from PulseView developer about the drama, go to 27:06
