Hello to all,
I'm opening this topic because I want to buy this PWM Fan Temperature Control Governor (
link):
![](https://ae01.alicdn.com/kf/S41c6a4ef23fb411db902de1a47abc089q.jpg)
Basically the governor automatically regulate a connected fan speed based on the detected ambient temperature.
The devices I want to connect:
Main problem is that the above fan is a 2 wire fan, so it will not work as is.
I'm wondering if the controller will be able to control fan speed if I connect the fan through a
MOSFET IRF520. From what I saw it seems to be possible, but samples show arduino and I'm not sure if can work at all with the board I want to buy:
![](https://rees52.com/cdn/shop/products/22083.jpg?v=1702154949&width=600)
![](https://community-assets.home-assistant.io/original/3X/c/9/c9af6448942c9922d06f58d054bc917d3ff5443b.jpeg)
There are other adapters in AE which seems to do similar jobs, but I have no idea on what could be the right one for my specific case. I suppose that IRF520 or similar modules convert PWN signals into DC, so I assume that it should work even with the water pump, right?
This is a new topic opened as consequence of
this one. Basically it was the same kind of controller, but designed for 2 wire fans. Main problem was maximum current supported by the fan interface (3A while the fan I need to use, as you can see, is 6A). No one has been able to help, so I'm opening this topic to see if I can achieve the result I want with a different approach, but the problem I have now is the inverse: the controller seems to be able to provide the power required by the fan (maximum drive current is 12A although I'm not sure is enough), but I have no idea if there are ways to make it work with 2 wire fan.
Any help would be very appreciated.
Thanks
