This answer is relevant mostly if you want to see the differences and not programmatically process them. You may skip it if it’s not the case.
Are you actually collecting data inside Excel (with VBA?) or is that an
XY problem? If the latter, next time please describe the actual situation — it will really aid helping you. I will assume you
do not use Excel, as that would both be a weird choice of a tool, and it’s unlikely that one first writes entire data collection code and then fails to iterate over rows to find new entries. In case you do, you may export data as a CSV file.
What you ask about is
creating a diff of two lists of rows. I believe they are ordered, as without that assumption the question can’t even be answered. If you have data in consistently formatted rows, for example a CSV file, there are many tools that can handle that. In *nix systems you have a
diff and
comm. In Windows you may use command
fc or a GUI application like
Meld or
Notepad++.
