Author Topic: mA and microA ranges not working on multimeter  (Read 3281 times)
Offline TechJunkie97Topic starter
« on: July 15, 2017, 05:53:29 pm »
Hi, I have a cheap multimeter from eBay (PeakMeter PM8233E). The microA and mA ranges are not working on it, except that everything works fine. I can still measure A by using 10A socket. The mA fuse is rated for 250mA and I am pretty sure that I never measured that much current with this multimeter. Also, the meter just shows some random low values( such as 0.05 mA) when connected in a circuit.
Offline Benta
Re: mA and microA ranges not working on multimeter
« Reply #1 on: July 15, 2017, 05:57:12 pm »
Fuse is blown. Someone tried to measure voltage using the mA range.
« Reply #2 on: July 15, 2017, 06:14:57 pm »
Thanks Benta! I'll replace the fuse. Just wondering, do I also need to check the voltage rating of the fuse? The manual says that I need 250mA/250V fuse.
Offline retiredcaps
« Reply #3 on: July 15, 2017, 06:17:04 pm »
Note this meter has two off positions and the uA and mA share the same input terminal as volts/ohms.
If the rotary switch is on the right side off position and you have probes plugged into a live source and then switch the meter on to measure volts, you have to pass through the A, mA, and uA first to get to volts.
Offline retiredcaps
« Reply #4 on: July 15, 2017, 06:19:20 pm »
Dave talks about uA/mA sharing the same input terminals as volts/ohms in this video below.
Offline Zero999
  • 0999
« Reply #5 on: July 15, 2017, 06:25:57 pm »
Wow, two off positions, one next to the current setting and the current sharing the same socket as the voltage! Talk about bad design. Thanks for posting this so I know to avoid meters like this in future.
Offline retiredcaps
« Reply #6 on: July 16, 2017, 01:32:50 am »
The following users thanked this post: Zero999
« Reply #7 on: July 16, 2017, 05:11:50 am »
Thanks everyone for replying. I actually didn't think much when I bought this multimeter. I saw some part of one of Dave's videos about multimeters and planned to buy a multimeter with auto ranging function. I usually work under 12V and 1A so I think this multimeter is just fine for me.
