Started to do some of the electronics and test gear in the shack today , started with an important piece of gear. A 50 Ohm dummy load, for tuning up transmitters before connecting to main antenna's, this one is oil filled, using 20 x1Kx3watt metal oxide resistors, the oil I used this time is vegatable oil which is fine aslong as you remember to change it after 2 Years, otherwise it gores rancid, I change mine every year.
I thought of using DOT 5 mineral brake fluid, but I wasn't sure how it would react to RF.
