I am probably going to end up with the MG stuff, I have used their contact cleaner, tuner spray, etc. although the shiny hardness of the nail polish has some appeal as far as verifying coverage.
Sprays I wonder if there are holes. (oh, actually, the MG chemicals spray has a "UV indicator" , so thats good)
"Contains a UV indicator for optical inspection"
Also, I wonder what the best procedure is with boards that have corroded a bit? I have some boards that have grown green stuff (cleaned now) in high humidity areas. It was on copper that wasnt coated with anything. Once its gently cleaned off with Qtips and IPA, and dried off.
My hope being that a coating stops further corrosion!
But I guess no after the fact treatment can't work miracles *LOL*.
