Author Topic: Connector help  (Read 2503 times)
Offline iloveelectronicsTopic starter
  • Country: hk
Connector help
« on: December 04, 2013, 02:37:57 am »
I recently got a used Data Precision 8200 voltage/current standard. It uses the attached connector for its 100mV output. Is there a name for this type of connector? Where can I buy a male plug that will connect to it properly?
The diameter of the inner black plastic part is about 16mm and that of the outter metal threaded part is 20mm.
« Last Edit: December 04, 2013, 02:39:33 am by iloveelectronics »
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
Offline rexxar
    • Forever Tinkering
Re: Connector help
« Reply #1 on: December 04, 2013, 03:52:16 am »
Pretty sure that's just a locking DIN connector. Mouser, DigiKey, and the like have them in almost infinite variations of pin count and arrangements.
Offline fluxcapacitor
Re: Connector help
« Reply #2 on: December 04, 2013, 04:08:53 am »
In the service manual it says its a 3 terminal shielded connector. I think it is a DIN as rexxar said.
http://www.ko4bb.com/Manuals/09)_Misc_Test_Equipment/DataPrecision_8200_6.5_Digit_Calibrator_Service_Manual.pdf
  • Country: hk
Re: Connector help
« Reply #3 on: December 04, 2013, 04:28:25 am »
Thank you! I'll look into these more.
Offline ConKbot
Re: Connector help
« Reply #4 on: December 04, 2013, 05:36:25 pm »
Make sure to get gold plated pins on whatever connector you get with such a low signal level.  100mV typically wont be enough to help break though an oxide layer if the connector doesnt have good wiping action when you mate it.
« Last Edit: December 05, 2013, 01:33:59 pm by ConKbot »
Offline Jim Beckford
Re: Connector help
« Reply #5 on: May 26, 2020, 06:42:47 pm »
This connector is actually a microphone connector. It is an Amphenol 91-PC3F. The mating connector is 91-MC3M. I've attached the datasheet. These are now obsolete. I found one on Ebay (NOS) and bought it. Be warned, though, that since these are used on microphones (both ham and professional), the audiophiles create a demand which runs the prices up. I also found several people making cables with the other end being an XLR connector. Hope this helps.
Gold plated pins were never an option. The contacts seem to be somewhat of a tuning fork with high pressure. I would not expect a problem.
The following users thanked this post: Electrole
