Author Topic: Silicone sealant (electronics grade)  (Read 13675 times)
Offline sweesiong78Topic starter
« on: September 30, 2014, 08:53:51 am »
Has anyone used this for securing parts around their boards:
http://www.ebay.com/itm/704-High-Temperature-Electronic-Devices-Silicon-Rubber-Adhesive-Sealant-Glue-45g-/121428794352?pt=LH_DefaultDomain_0&hash=item1c45b85bf0
I was looking for electronics grade silicon on amazon but they were either super expensive or brands like Permatex which are acid curing.
Offline nanofrog
Re: Silicone sealant (electronics grade)
« Reply #1 on: September 30, 2014, 10:34:12 pm »
GE Silicone II you can find locally is suitable for electronics use.
« Reply #2 on: October 01, 2014, 12:20:02 am »
Thanks!
Offline nixfu
« Reply #3 on: October 01, 2014, 12:39:39 am »
Most manufacturers just use "Hot Snot" aka hot glue.
Offline Timmay
  • Electrical Engineering Student
« Reply #4 on: October 01, 2014, 07:34:34 am »
Non-acidic is essentially the pivot point for non-electronics grade silicon and electronics grade silicon, in general. GE Silicone II is good to go, but you will find others. Just check the MSDS for acidic compounds and for more advanced sealants conductive compounds which is required for some to make perfect grounds on aircraft aluminum, yes that is a bit above and beyond but since I have used sealants specific to grounding I figured I would mention it.
Before you take my advice, know that I have 12 years experience as an aviation electrician and am currently a junior perusing a degree in EE. Barely wet behind the ears. I respect everyone's opinion, could be wrong and love to learn. Please don't hesitate to correct me. ;p
Offline ConKbot
« Reply #5 on: October 01, 2014, 09:52:20 am »
Your normal every day RTV silicone is 'Condensation cured' where atmospheric moisture is what makes it cure.  There are 3 general kinds. Acetoxy cure, which is the cheapest, bonds well, but releases acetic acid on curing (the acid ingredient in vinegar) And corrodes copper and lots of other metal. Even sealing an enclosure with it, the trapped fumes inside can corrode the items.  The other two kinds are neutral cure, but still slightly different.  Oxime cure which releases a ketone on curing. This can corrode copper on contact, but isnt as bad to use near electronics, just not directly on copper.  The most desirable for electronics is Alkoxy cure, which releases methanol. Mind the fumes from all of them, but if you have a large surface area covered, Acetic acid fumes can be pretty nasty. Though your nose will give you plenty of warning that something isnt right.
The GE silicone II, as mentioned, is generally available locally (at least in the US) and is Alkoxy cure, so +1 to nanofrog on that being a good choice.
The following users thanked this post: BravoV, innkeeper
Offline nanofrog
« Reply #6 on: October 01, 2014, 02:16:35 pm »
Ticks the right boxes in the US at least (suitability, easy to find, and inexpensive).  :)
Online wraper
  • Country: lv
« Reply #7 on: October 01, 2014, 07:07:38 pm »
Only if they are One Hung Low. Hot glue is completely unreliable, will fall off by itself after a few years maximum. Also it is completely unsuitable if it will be exposed to high or low temperatures.
« Reply #8 on: October 01, 2014, 07:52:30 pm »
IS one hung low a racist joke?
Offline ConKbot
« Reply #9 on: October 01, 2014, 09:04:26 pm »
Offline codaroma
« Reply #10 on: June 24, 2022, 03:10:57 am »
I bought Dowsil 1080 which says "Electrical Grade" and "Electrical/ Electronic Devices" on the tube. But beware it is an Oxime cure sealant and so is corrosive to copper.
Offline codaroma
« Reply #11 on: June 24, 2022, 04:03:22 am »
As far as I am aware there are 4 main types of silicone sealant
Acetoxy cure - releases acetic acid (vinegar), very corrosive to lots of metals including copper.
Oxime cure - releases either methyl ethyl ketoxime or dimethyl ketoxime (these are not ketones, but oximes, unlike what ConKbot says), these can corrode copper.
Alkoxy cure - releases an alcohol, either methanol or ethanol, does not corrode copper.
Acetone cure - releases acetone (also know as dimethyl ketone, this is nail varnish remover, and is a ketone), does not corrode copper. Not good with some plastics
The last 3 are classed as neutral cure.
Useful resource -> https://cht-silicones.com/download/446
The following users thanked this post: Cubdriver, ebid
