Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Components References (Values)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Components References (Values) (Read 943 times)
yalect
Regular Contributor
on:
December 30, 2021, 10:08:17 am »
I would like to ask you that I want to buy some semiconductors components.
what best kind or type of
Op Amp
by looking to its features like
bandwidth frequency
and
voltage
do you think and in other hand its price like :
LM741 ,……………..
and
transistors : NPN PNP FET
Bf199, 2n2222………………………………….
Thank to hear from you much values.
Thank you
Last Edit: December 30, 2021, 10:12:12 am by yalect
Logged
trp806mo
Regular Contributor
Country:
Re: Components References (Values)
Reply #1 on:
December 30, 2021, 10:35:11 am »
Check the series of DAve
For example : EEVBlog 1436 - The TOP 5 Jellybean OPAMP's
I used to buy from Alli kits already done in order to have some legacy references try this kind of Keywords "50Pcs/box 10 Values Mosfet Transistor Kit IRF3205 IRF640 IRF740 IRF830 IRF840 IRF530 IRF630 IRF820 IRFZ44 IRF9540 IRF820"
But ypu have to chose what you want (high voltage, BJT, MOSFET, ...)
Logged
rstofer
Super Contributor
Country:
Reply #2 on:
December 30, 2021, 08:18:46 pm »
Small signal transistors: 2N2222A, 2N3904, 2N3906
Small signal diodes: 1N914, 1N4148
Power diodes: 1N4001-1N4007 - check datasheet for voltage/current ratings
Op Amps: Watch Dave's video, referenced above, LM358
Logged
yalect
Regular Contributor
Reply #3 on:
December 30, 2021, 08:39:02 pm »
Maybe there are other references or values list of
Op amp
and
transistors
(FETs, BJT, ....) I based more on frequency range and medium voltage or more.
Thank you
Logged
rstofer
Super Contributor
Country:
Reply #4 on:
December 30, 2021, 08:55:28 pm »
Some manufacturers have parametric search capabilities:
https://www.analog.com/en/parametricsearch/11085#/
Some suppliers also have parametric search:
https://www.digikey.com/en/products/filter/linear-amplifiers-instrumentation-op-amps-buffer-amps/687
https://www.digikey.com/en/products/result?s=N4IgTCBcDaIC4CcCGA7AzgSzXA9gtIAugL5A
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
