Here follows a list of the most commonly used parts in a hacking/tinkering environment. If you don't know what you need, you can most probably start with something from the list.
I _will_ make mistakes so please correct me. Since this list is intended for beginners, I will prefer through hole/DIP than SMD. Specs come from the datasheets, I will try to have as much info on each part as possible while still keeping it compact
Diodes
Silicon
1N4001 - 1N4007 (1A, 1V drop)
1N4148 (200mA, 0.7V drop)
Schottky
1N5817 - 1N5819 (1A, 0.4V-0.9V drop)
1N5820 - 1N5822 (3A, 0.4V-0.9V drop)
MBR735, MBR745 (7.5A, 0.48-0.68V drop)
Zener
BZX79 (0.5W power dissipation, 37 types with voltages from 2.4V-75V)
TVS
1.5KE
Transistors
BJT
BC548 (NPN, 100mA, 30V)
BC558 (PNP, 100mA, 30V)
2N3904 (NPN, 200mA, 40V, Ft=300 MHz)
2N3906 (PNP, 200mA, 40V, Ft=250 MHz)
2N2222 (NPN, 800mA, 40V, Ft=300 MHz)
2N2907 (PNP, 600mA, 60V, Ft=200 Mhz)
TIP120 - TIP122 (NPN Darlington, 5A, 60-100V)
TIP125 - TIP127 (PNP Darlington, 5A, 60-100V)
TIP33x (power NPN, 10A, 40-100V)
TIP34x (power PNP, 10A, 40-100V)
FET
Mosfet
2N7000 (N-Channel, 60V, 200 mA, 1.2Ohm)
BS170 (N-Channel, 60V, 500 mA, 1.2Ohm)
IRF510 (Power N-Channel, 100V, 5.6A, 0.54Ohm)
opamps (specs vary with temp/supply etc. These are ballpark figures)
LM358/LM2904 (single supply, 0.7Mhz, 20mA out, out range Gnd + 5mV-> +Vcc - 2)
TL071-TL074 (single/dual supply, 3Mhz, out range -Vcc + 1.5V -> +Vcc - 1.5V)
LM324 (single supply, temp compensated, 1Mhz, 20-40mA out, out range Gnd + 5mV -> +Vcc - 1.5V)
CA3140 (single/dual supply, 4.5Mhz, out range -Vcc + 1.4V -> +Vcc - 2V)
TS922 (high out current, single/dual supply, rail to rail, 4MHz, 80mA out, out range -Vcc + 0.1V -> +Vcc -0.1V)
comparators
LM393 (2x, single/dual supply, 1.5Mhz)
LM339 (4x, single/dual supply, 1.5Mhz)
LM319 (2x, single/dual supply, 6Mhz)
To be continued with as many common parts as I can. Some suggestions on models of optocouplers, mosfet drivers, P-mosfets and logic level N-Mosfets are welcome
Original:
Hello Everyone,
I'm in the process of buying parts to fill my workbench drawers with components in order to have them available for the next prototype idea that I want to build in 5-10 minutes. Problem is, when I search for parts there are so many choices that I am not really sure which one would fit the bill. I need some suggestions on the most common building parts that someone should have on the workbench at all times - meaning, specific part numbers. Although I already found bjt (bc548)/mosfet (2n7000)/diodes (1n4148) and some others, I would really like to hear what everyone has to say.
Ideally I would like to have suggestions for opamps (standard/rail2rail), different types of diodes, comparators, signal/power transistors (fet & bjt), voltage references, voltage regulators etc, as well as more specialty items like the 555 which although has a more specific use, it is "mandatory" on a workbench.
If we come up with enough info, I will edit this post to add a nice list so everyone can have it as a reference
