Author Topic: VHDL; State machines and syntax!  (Read 7703 times)
Offline McPeteTopic starter
  • Layout Designer, AKA eCAD monkey
« on: February 23, 2012, 11:41:32 am »
Hey all,
Another quick question on VHDL. I have a series of IF statements controlling a state machine's transition through states. Several are timed. What I've used sucessfully in the past is;
IF       (cntint = 0 AND updwn = '0')
      THEN IF    (manclk'EVENT AND manclk = '1')      -- Defines lower limit and reset!
      THEN      cntint <= 63;
END IF;
END IF;
What I'm trying to do this time is this;
(Errors highlighted in red)
IF (STATE = S0)
THEN IF (CLK100h'EVENT AND CLK100h = '1')
THEN (tint30 <= tint30 + 1);
THEN IF (tint30 = 3000)
THEN STATE <= S1;
END IF;
END IF;
END IF;
'Error (10500): VHDL syntax error at PTMFSM.vhd(40) near text ";";  expecting ":=", or "<=" '
Where am I going wrong here?
Thanks!
Offline TerminalJack505
Re: VHDL; State machines and syntax!
« Reply #1 on: February 23, 2012, 12:22:23 pm »
It looks like you have an extra 'THEN'.
IF (STATE = S0)
THEN STATE <= S1;
END IF;
END IF;
END IF;
I'm guessing you meant to say this...
IF (STATE = S0) THEN
    IF (CLK100h'EVENT AND CLK100h = '1') THEN
        IF (tint30 = 3000) THEN
            STATE <= S1;
        END IF;
    END IF;
END IF;
Edited to add:
By the way, you're pushing your luck by using signals that way.  The tint30 signal should probably be a variable.  A signal isn't guaranteed to be updated immediately--only after the process completes.  So the value that you're checking against in the statement following the assignment won't necessarily be the value you just incremented the counter to.
You probably won't get burned by that code since tint30 is just a counter but it's still bad form.
« Last Edit: February 23, 2012, 12:45:54 pm by TerminalJack505 »
Offline slateraptor
« Reply #2 on: February 23, 2012, 01:25:34 pm »
Previous comment amended. Your FSM is bad form in general; consider revising in the order 1) check for rising edge, 2) determine current state, 3) execute statements for applicable state.
By the way, you're pushing your luck by using signals that way.  The tint30 signal should probably be a variable.  A signal isn't guaranteed to won't be updated immediately--only after the process completes.  So the value that you're checking against in the statement following the assignment won't necessarily be the value you just incremented the counter to.
Offline Blofeld
  • Diamonds Are Forever
« Reply #3 on: February 23, 2012, 03:54:43 pm »
Just found this free VHDL introduction today:
www.freerangefactory.org/dl/free_range_vhdl.pdf
Perhaps if you are unsure about some concepts it may help to take a look at it.
My site www.wisewarthog.com and my Youtube channel (in progress). Links and reviews of books and free stuff.
« Reply #4 on: February 23, 2012, 04:37:49 pm »
That's a really nice book.  Especially for the price!
Thanks for pointing it out.
« Reply #5 on: February 23, 2012, 09:42:54 pm »
Hi All,
Thanks for the pointers!
It's been a "teach yourself with little to no guidance" experience for me with VHDL, so it's good to get some experienced advice.
With regard to variables, should I be declaring STATE (currently defined as a "TYPE") as a variable too?
Thanks!
« Reply #6 on: February 23, 2012, 10:03:13 pm »
Hi All,
Thanks!
No, it probably isn't necessary to declare STATE as a variable.  You will typically want to use signals rather than variables, when possible.
Here's a table from one of the books I have that summarizes when to use signals or variables...
SIGNALVARIABLE
UtilityRepresents circuit interconnects (wires.)Represents local information.
ScopeCan be global (seen by entire code.)Local (visible only inside the corresponding PROCESS, FUNCTION, or PROCEDURE.)
BehaviorUpdate is not immediate in sequential code (new value generally only available at the conclusion of the PROCESS, FUNCTION or PROCEDURE.)Updated immediately (new value can be used in the next line of code.)
UsageIn a PACKAGE, ENTITY, or ARCHITECHTURE.  In an ENTITY, all PORTS are SIGNALS by default.Only in sequential code, that is, in a PROCESS, FUNCTION, or PROCEDURE.
« Reply #7 on: March 01, 2012, 09:01:18 am »
Thanks all, I've cleared all my errors surrounding syntax now.... I'm even getting my CASE statements to work!
However, I'm now getting errors from each line of each state progression setup, where I reference STATE directly.
I've declared STATUS as a TYPE, and then associated it with a signal, STATE, as follows;
TYPE STATUS IS (S0, S1, S2, S3, S4, S5, S6, S7, S8, S9, SA, SB, SC, SD);      -- All avalible states of FSM
SIGNAL STATE: STATUS;
The error Quartus is giving me is;
"Error (10514): VHDL aggregate error at PTMFSM.vhd(51): can't determine type of aggregate -- found 0 possible types"
What precisely does that mean?
Thanks!
P.
Offline electrode
« Reply #8 on: March 01, 2012, 09:41:15 am »
While my VHDL may be crusty, that certainly looks correct. I even dug up an old project of mine and your code is identical to mine for the declarations (other than naming, of course).
My guess is the problem lies elsewhere in your code, perhaps with an illegal assignment to your signal.
« Reply #9 on: March 01, 2012, 03:49:07 pm »
Those two lines of code look okay.  What's at (and around) line 51?  It looks like that's the line it has a problem with.
« Reply #10 on: March 03, 2012, 08:40:21 am »
Just came back to it with fresh eyes.... I had this;
51: IF (STATE <= S1)
Instead of this;
IF (STATE = S1)
Silly newbie mistake!
