Hi All,
I am working on a simple scale using some strain gauges, which is my first time working with differential analog signals. There is a initial amplifier with 1000 gain that takes in the differential signal from the two sides of the wheatstone bridge, and outputs an amplified differential signal into a ADC (ADS8865). Now, both the ADC and the amplifier take in a reference voltage, I didn't think long and hard when making my prototype, and I have a two volt reference (Rest of the system is 3.3V just if curious) being fed into both. Inside the amp datasheet, it states "The REF pin is also available on this device and can be used to provide a DC shift of the output signal" so my first question is, do I even need this pin and a offset? My prototype works while feeding in 2V to REF, and I see a 2V offset on the signal, but I want to do this correctly. As far as the ADC is concerned, it supports "input signals with a differential input swing of –VREF to +VREF. " and I'm assuming the REF is setting the maximum difference it can read between the two differential lines, to support the fact even though there is an offset of +VREF which is the positive limit the ADC can still measure weight I put on the gauge.
Am I correct? Can I ground the amp's ref pin or should I keep a DC offset from the amp?
Thanks,
Samuel
