Hello everyone,
I'm pretty much a newbie when it comes to electronics, but now i'm making my first steps and i encountered a problem.
I wanted to use a CMOS buffer for something ( i will go in more details if necessary) the 4050B
I connected the Vdd(3.3 V) and Vss(0 V), simple enough. Now i connected on the first input a 3.3V input..here is the problem
My output is 3.3 volts until i connect something, after i connect some LED or something else the voltage drops to 1.7 V or something like that.
I want to know why this happens and what can i do to fix it, or use to get my desired result.
I suspect that what i'm asking here is 4th grade physics but i simply don't understand what is going on..
Thank you
