Author Topic: ELMDuino not reading PIDs correctly  (Read 926 times)
Offline bborisov567Topic starter
  • Country: bg
« on: October 11, 2022, 03:20:54 pm »
I am trying to read live data on my '01 clk200. ELM327 works correctly with the smartphone app. Also tested it through terminal and it works fine. I have it connected to Arduino uno and running the example sketch(it's on the github page of the library, linked below), just changing the respective functions. I tried intakeAirTemp() and i am getting 168, on rpm() i get 0 and when i try engineCoolantTemp() i get ELM_Timeout error, last picture is engineCoolantTemp() with debug turned on. Here is a link to the library github: https://github.com/PowerBroker2/ELMduino
Offline mikerj
Re: ELMDuino not reading PIDs correctly
« Reply #1 on: October 11, 2022, 08:50:56 pm »
Is the ELM actually connecting the the cars ECU? Have you tried checking the return value from myELM327.begin() to ensure it correctly initialised?
  • Country: bg
« Reply #2 on: October 12, 2022, 06:14:39 pm »
By default protocol is chosen automatically, so the elm should connect to the car.
The last picutre is with the debug mode on /myELM327.begin(2000, true)/. I usually get ELM_TIMEOUT response when the elm has trouble connecting to the car.
