Author Topic: Gould DSO 4092 Eye Diagram or Eye Pattern (Persistence)  (Read 640 times)
Offline stojkeTopic starter
  • Country: cs
« on: August 09, 2022, 08:12:45 am »
Is it possible that these high end models from early 90s, even tho costly then, do not support something as simple as an eye pattern?  :-\
I have recently purchased a Gould DSO 4092 oscilloscope , rebranded as Siemens Oscillar D1052 , and simply can not find any settings relating to getting a proper Eye diagram for checking Compact Disk players  and etc.
What ive read is that digital oscilloscopes , older ones, do not have this, and that newer ones use something called persistence (I guess it just keeps the trace on the screen for a little while longer after drawing it).
Should I sell this thing and get an analog scope , there is one Hitachi V-1085A here I can get.
Offline m k
Re: Gould DSO 4092 Eye Diagram or Eye Pattern (Persistence)
« Reply #1 on: August 20, 2022, 01:16:48 pm »
Your alternative is 100 MHz analog, Gould DSO 4092 is 8 bit 800 MS/s.
What kind of, say 50MHz, when DSO has 16 dots/cycle, comparison that will generate on screen?
Maybe early DSO makers didn't believe it doesn't do harm if some functions are sort of low freq. only.
Can't you have both?
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-YFE
  • Country: cs
« Reply #2 on: August 29, 2022, 05:11:35 pm »
These devices are too bulky and take too much space, one is too much... The scope comes close to making an eye pattern if only I could slow down the display to keep the traces on a while longer, dont know if it is possible to program it to do so as it has programming via Serial.
  • Country: cs
« Reply #3 on: October 12, 2022, 03:23:57 pm »
Anyone?
