You can think of this overall topic as being analogous to “zooming in” to see more detail of a signal while also being able to see the zoomed out view. This helps you see the detail in the zoomed in version while retaining a reference to where the detail resides in the zoomed out view.
This technique for navigating both the detailed and larger signal views at the same time was popularized on analog oscilloscopes. Today on digital oscilloscopes it is handled in a different manner (both externally by the user and internally by the scope) but with a similar result and is generally referred to simply as “zoom”.
The following videos will reinforce what basinstreetdesign has described by helping you visualize A, B, delayed timebase, etc, with examples of how and why they are used. (Each manufacturer and model may differ somewhat in control layout but the concepts will be pretty similar if the features and functions are present on the scope.)
https://youtu.be/J-7MycqHPOshttps://youtu.be/54roz8IUoVIW2AEW is a major resource for anyone learning to use oscilloscopes and other test equipment, and he is a wonderful teacher of many aspects of electricity and electronics. He has a ton of highly valuable videos, check them out.
