Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
How to wire a Current Transformer
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How to wire a Current Transformer (Read 811 times)
anishkgt
Frequent Contributor
Country:
on:
August 13, 2018, 05:22:04 am »
Hi All,
Is there anything else that i would need when using a Current Transformer ? I will be using this with an arduino to measure AC current of a Spot welder. The current schematic of the Current Transformer is from its data sheet (
http://www.tamuracorp.com/clientuploads/pdfs/engineeringdocs/L06PXXXS05.pdf
The optocoupler is to sense when the electrodes are shorted for a spot weld.
Logged
Dave
Super Contributor
Country:
I like to measure things.
Re: How to wire a Current Transformer
Reply #1 on:
August 13, 2018, 06:20:27 pm »
That is not a current transformer, but rather a hall effect current sensor. Yes, your connection method is correct.
Logged
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
anishkgt
anishkgt
Country:
Reply #2 on:
August 16, 2018, 09:13:08 am »
Thank you appreciate it.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
