Hello all, the subject sort of sums it up but I may well have missed that boat. I'm playing with/learning about RS232, RS422 and RS485 and would like to interface with devices using all of them. RS232 and RS485 as I already have devices that talk using those physical interfaces. RS422 however seems to have slipped away. A search on eBay will throw up any number of interface devices which will convert an RS422 device to USB or whatever but nothing seems to actually use it. I guess given it's a bit more complicated then the other two nobody uses it for simple temp sensors or whatever.
I guess I could create two ends of an RS422 interface with a PCB design but both ends could be wrong and I'd never know. If I had something which I was fairly confident was communicating properly and I could communicate with it I'd feel happier.
Any thoughts or let it go? I assume that there's a load of 422 legacy kit still used in industry?
