Hi guys could you help me understand with this ??
i’m trying to understand how one would choose a correct power supply for this iron..
or any other thing really...
paulca mentioned that his is running his iron on a 19v 6.5A supply. so more amps than stated in the manual is ok..
So i decided to google it first and see if i understand what’s going on??
my google search query; amps vs voltage power supplies
first result: here mentioned that higher Voltage would be bad.
and lower not always good .. i do understand that that’s not the case with the TS100 it can operate using lower current..
It does answer the Current rating or amps (i did see a youtube clip explaining this)
(need to watch more examples hahah)
So more amps is ok the device wil just use what it needs..so far so good i understand the first part
https://electronics.stackexchange.com/questions/34745/choosing-power-supply-how-to-get-the-voltage-and-current-ratings?utm_medium=organic&utm_source=google_rich_qa&utm_campaign=google_rich_qai must admit that the last part advanced concepts are a bit harder to understand i need to read it a couple of times..
btw Maco Reps mentions something about an “input Voltage pre regulator” RT7272B.
https://youtu.be/HgrB5P-rDLw?t=8m47si still don’t know how this fits with what Paulca mentioned:
quote : I was advised that the full 24V might stress the main mosfet too much and to aim for the 19V laptop supply. end quote.
After reading the Advanced Concepts from the link mentioned earlier i think i’m starting to understand what Marco Reps mentions
about the RT7272B being able to handel an input range between 4.5v to 36v.. that could be for safety and the Ripple mentioned on EESE site??
i have to admit i’m not completely there yet..my current instinct would be to say don’t go over the 24v limit and more watt is ok more amp is ok.. but stay at least above 65w
