Have you read this entire thread, only 2 pages? Reason I ask, is most of you new questions have been answered.
This power supply is all you need:
https://www.tme.eu/en/details/gst90a24-p1m/desktop-power-supplies/mean-well/
i have read all the comment's and the reason is i'm trying to understand and not just do..
i downloaded the TS100 manual and the power supply your pointing to is exactly the max specs of the iron...(page 5 of the manual)
24v 2.7amps and they recomment 19v 2.1amps..
the reason i'm asking reading is that i want to learn and understand why i'm going for a or option b instead..
from what i understand until until now.
1) use a 24v supply (no more than that)
2) more amps is ok but don't go overboard and after seeing this vid probably stay near the 2.7A.
https://youtu.be/g-xXSJagz_A
reason a faulty tip could result in a short of the mosfet (did'nt even know what a mosfet was before today
3 getting more power could be a good idea but again no need to go overboard. Running the power supply at lower load could be beneficial to longevity say 90wats more than enough keeping the price low..
So that's where i'm at now..
I appreciate you are most likely on a limited budget, at least here in the US, on Amazon, you can get the TS100 KIT, it comes with the 19 volt PSU and one tip for $65 US. I wanted the full 65 Watts the unit can deliver, so I wanted a 24 volt PSU, and would have preferred buying just the iron for less, but they only sold the kit package on Amazon. You can buy just the iron alone, and these are available on all the usual Chinese sites. First, I don’t like waiting for 6 week deliveries from those sites, and if the product has any issues, Amazon’s return policy is very easy and good, so I pay a bit more for those two factors.
I watched the video you linked, I remember watching his glowing first review, same guy. Did you read the text he posted on his YouTube review?
He states: “However, if you use a power supply with which can deliver more than 5A, you risk that the maximal current (5A) of the MOSFET is exceeded and you burn it - when the tip fails.”
You see he says “WHEN THE TIP FAILS”. These inexpensive TS100’s have been on the market for over 1.5 years now and I have never seen any online posts complaining about failed tips, I own 6 tips, they all work fine, but granted anything can break, seems he got a bad tip, and used it twice on two different TS100’s, with the same bad results. As someone who over research’s products, (not as much as you
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
, I’ll tell you, at some point you have to jump in the pool to get wet! I’m just glad I’m not your new car salesman.
The 24 volt MeanWell PSU that I and others here have recommended is NOT 5 amps. If it concerns you, simply buy the KIT with the 19 volt PSU, or buy one with the same specs.
Seems he is using whatever power supply he had on hand, but the main issue he had was a FAILED TIP or TIPS. He had this problem twice, so I assume he used the same “shorted” tip on his 2nd unit, and broke that one as well. It makes sense to use a DMM and check the tips before first use.
If you don’t want to bother making your own silicone cable, I posted the solution for that in one of my earlier responses to you in this thread.
Sounds like you may be a better candidate for a more standard soldering station where you don’t have to worry or wonder about these details. You could buy cheap Chinese clones of know brands, or better yet save up for an original Hakko 951, or the new Pace 200, for about $240 US. Those dedicated soldering stations should last for many, many years. I suspect at the price point of the TS100, it will fail far sooner, and the money spent on it will be lost. Thankfully not an issue for me at this time, and I wanted to try it out since it uses the new direct drive temp sensing tips, which both the Hakko and Pace units use. Just remember, compared to the two I mentioned, many people here and online consider the TS100 as a TOY. I understand where they are coming from, and if I were a solder pro, semi-pro, or needed long term reliability, with good customer support, I’d buy either of the other two. Since I don’t solder much, my needs are far less demanding, and I hope I get a decent amount of life out of a TS100. If not, I didn’t lose much investment in it.
Good luck on whatever you decide.
