Hello,
I'd like to start learning vacuum tubes at the fundamental level but in a practical sense. I want to gain an understanding how the tubes work, how to properly provide all the necessary voltages to grids etc.
Honestly, I don't know where to start.
I'm mostly interested in vacuum tubes RF applications and maybe somewhat in audio amps but not much in the latter.
When I read the audio tube amp forums the guys there seem to be very knowledgeable and are discussing fine circuit details that I'm not sure even how to interpret. Too advanced for me. Not many are interested in RF tube electronics so I doubt I can find any active forum for that.
I have a few questions that you might answer to steer me in the right direction of tube learning path:
- Is it practical to assemble a universal Tube Lab Power Supply for "tube breadboarding"? Such an LPS would have to provide several variable voltage outputs for various tube types according to their individual requirements. Does anyone know of such an LPS schematics?
If there is no standard solution how would you regulate voltages from a standardized FSU
anode series
transformer (TA) such as this one:
TA175-127/220-50, having the following specs (in the 220V mode):
* Power: 86VA, 0.45A primary
* Secondaries (two windings of each): 2x315V (0.065A each), 2x125V (0.14A each), 2x35V (0.14A each)
The voltage sets look like a good compromise for various basic tube types, aren't they?
- What types of high voltage non-polar capacitors are suitable for tube circuit applications? Will, for instance, basic Asian polypropylene film capacitors such as these ones...
https://aliexpress.com/item/1005002535062542.html... work in RF circuits up to say, 150 MHz ?
If NOT, what types of high voltage capacitors are most suitable for that application? Please advise.
- Are there any good practical tube books in the style of "Make Electronics" that would guide the tube learner in a step by step manner? It looks like not, just because such books are more recent trend and in the 1960's when tubes were still popular there were either quite a few academic tube books with piles of formulas on the one hand or otherwise short "assemble this that way" brochures on the other with no insights into how the circuits work.
- One specific question. Why is there often a choke used in the tube power supplies like L1 in the attached schematics? Semi- PS circuits get away without it.
![How to approach vacuum tube circuits exploration? 2328853-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=435799.0;attach=2328855;image)
All in all, I'd like to approach the tubes study in an organized and consistent manner but what would give me the best guidance for that task? I doubt there is a single 'Know it all' resource for tube circuits but I need to start somewhere.
