Author Topic: Choose an inductor and capacitor for AOz3103di buck converter  (Read 1571 times)
Offline nourTopic starter
  • Country: sa
  • calm down, it is just a smoked oPamP!
I want to build a Fixed 5v buck converter with 2.5 Amps output from a 12v input, I will be using AOZ3103DI.
I want to select the inductor to be able to handle the output current with minimal output ripple, I have tried to read the datasheet but I am a little bit lost.
Link to the datasheet
http://www.aosmd.com/res/data_sheets/aoz3103di.pdf
if what I have wrote doesn't make sense for you or you think there is something wrong, please correct me, I am still beginner and what I know probably less than what you know
  • Country: sa
Re: Choose an inductor and capacitor for AOz3103di buck converter
« Reply #1 on: July 27, 2017, 07:59:29 am »
I am expecting the load to range from 1-2.5 amp
  • Country: sa
« Reply #2 on: July 27, 2017, 09:10:42 am »
Ok that is very good, what about the capacitor, the CC and the CBST
I don't know why don't they give values for the typical application, at least recommend one or two general outputs like 5v or 3.3v?
Thanks
  • Country: sa
« Reply #3 on: July 27, 2017, 09:38:25 am »
Thanks a lot, I think for the Cout I will go for low ESR 100 or 220uF tantalum cap for 2.5A
