Say you want to measure the startup activity of an unknown power supply, but you don't have a clue what the amplitude or frequency of that signal is going to be. You want to use single shot to do the capture but, since the signal is unknown, you're not sure what to set your volts and time/division values to so that the waveform displays properly. Your scope also has a limited memory buffer, which makes post-capture adjustments somewhat difficult.
What would you do in this situation? Would you keep re-taking the capture, adjusting the scope's settings each time until you get something you can adjust properly? I guess there's no auto triggering-like feature when using single shot, so I'm just curious what approach one would take in this situation.
