@kardacz click under "attachements and other options" when you reply.
The file has to be one of the following extensions: doc, gif, jpg, pdf, png, txt, zip, tar, c, h, hex, bas, xls, odt, asm, wav, aiff, wma, mp3, flac
you can only put up to 25 per post for a maximum total size of 2000KB. and a single file can't be over 1000KB.
Once you are able to attach it, there are ways to make a link to the attached image, but we can get there once you are able to attach the image.
