Author Topic: Cheap way to split 48v battery into 36v and 9v?  (Read 1481 times)
Offline Sagar
  • Country: in
Re: Cheap way to split 48v battery into 36v and 9v?
« Reply #25 on: August 06, 2024, 11:17:02 am »
I will suggest to use 9v500mA zener for MCU and for 36 volt you can use any buck converter which suits the current requirements. I did not find any currentratings in the post, if you can mention that I suugest you a cheap option. Because voltage can be divided even by using resistor divider network but please mention the application, where you want to use it.
