Author Topic: Changing TCR with time  (Read 779 times)
Offline analitykTopic starter
« on: September 18, 2022, 12:00:45 am »
Hello.
Resistors have TCR. Ordinary carbon resistor have +-200ppm and more. But now i have looking for resistor, where i do not care about absolute value even in changing temperature, but i have to know how big change of TCR is in time. I want use it in thermostate, for polarisation of NTC. Nomen-oment for NTC resistor drift of TCR are specified.
Did i should use low TCR resistors (metal film) or ordinary carbon film resistor can fit in my ideas?
Sincerely.
Simon
Offline Teledog
Re: Changing TCR with time
« Reply #1 on: September 18, 2022, 04:44:04 am »
Check the spec sheets for the resistor(s) you intend to use?
Vishay & similar are available online, with derating factors, etc.
Offline Gyro
« Reply #2 on: September 18, 2022, 08:59:35 am »
Just use a metal film resistor. The change in TCR with time should be insignificant.
Best Regards, Chris
Offline Terry Bites
« Reply #3 on: September 18, 2022, 09:58:08 am »
Are you needing to linearise a thermistor. Is the TC of the linearising resistor that interests you?
The TC of the thermistor is very large compared with any fixed resistor. So the TC of the the fixed resistor has almost no effect.
Offline strawberry
  • Country: lv
« Reply #4 on: September 18, 2022, 11:36:01 am »
carbon film ~200ppm minimum
metal film =~ thick/thin film
thin film is relatively better stability
bulk metal  0..10ppm max
resistor dimensions/construction affect long term stability
even some carbon film resistor go bad after ~40y
Offline Terry Bites
« Reply #5 on: September 19, 2022, 06:18:14 pm »
Its worth mentioning that TC for ordinary resistors is sometimes specified as postive or negative or both. TC is a poor predictor of resistance change with T. There's no guarantee that the TC does change with T.
TC is not a parameter you want to use in a design- usually just the oposite.
Resistor ageing is unpredictable. But generally you get what you pay for.
Offline strawberry
  • Country: lv
« Reply #6 on: September 19, 2022, 07:08:15 pm »
carbon film vs wirewound
heat them in oven to 100C deg.
what chemical compound or solid metal will change its properties
