Author Topic: TENMA 72-8225 40Mhz Oscilloscpe DAT file  (Read 1013 times)
Offline simon christoTopic starter
« on: April 29, 2019, 08:08:14 am »
Hi there! This is my first post. I've got a Tenma 40Mhz Oscilloscope and it has a feature that can store
100 seconds of a particular channel on a USB stick.The waveform stored is a DAT file, and I'm having
troubles displaying it on a PC computer.I couldn't store it as an attachment, as the limitations on this
site doesn't allow it.It has no commas, so it's not a CSV file, it just 8 bit hex, one after the other.
Where would I get a DAT reader to display this waveform.Thanks Simon.
Offline connectTek
Offline connectTek
Re: TENMA 72-8225 40Mhz Oscilloscpe DAT file
« Reply #2 on: April 29, 2019, 08:54:13 am »
https://www.manualslib.com/products/Uni-T-Utd2042c-8824268.html
The Tenma is the same as UTD2042C
Read the manual.
It states you can only read data file on scope.
But you should be able to save as bmp format.
Sent from my TA-1012 using Tapatalk
