I've never heard of E4 before, normally electronics are found in E3, less often E6, occasionally E12 and very rarely other odd values.
As a general rule, you only need E3 between 10nF and 1uF as this range is normally only used for supply decoupling, below 10nF you may want to go with E12 or even E24 but it depends on what you're doing,
