Author Topic: Cascading counters, something I do not get  (Read 796 times)
Offline MoriambarTopic starter
« on: January 06, 2021, 03:00:32 pm »
Hello,
I was trying to experiment with some spare parts that were gifted to me and I stumbled into counters. Specifically, I have a load of 74AC163 (4 bit synchronous.
I was trying to cascade a bunch of them and count at different speeds (up to 10 or 20 MHz). Then I am puzzled.
The RCO pin, if I underrstand correctly is to be fed forward to the CLK of the next-in-line counter, in order to cascade them, BUT that pin transitions from low to high when the count is 0x0F, not when it is reset after a 0x0F (ie count of 0x10). So doesn't this produce the count 0x1F before the count 0x10?
I hope I made myself clear, I know I'm in the wrong, but I don't know how. Thanks
Offline Andy Watson
Re: Cascading counters, something I do not get
« Reply #1 on: January 06, 2021, 03:41:32 pm »
No. The RCO should connect to the ENT of the next counter. This will enable the clock of the next counter - whenever that clock occurs. Note, all counters should share the same clock.
The following users thanked this post: Moriambar
« Reply #2 on: January 06, 2021, 04:34:16 pm »
ah! That's it, thanks
Offline Benta
« Reply #3 on: January 06, 2021, 05:55:36 pm »
This could help:
https://www.eevblog.com/forum/oshw/how-to-programmable-divide-by-n-counters-using-standard-logic/
The only difference between 74AC161 and 74AC163 is the RESET signal, which is unimportant here.
