Hi Guys,
I am replacing some Caps on an old Kenwood Amplifier,
I tested the main smoothing caps after the rectifier, they are rated at 6800 uf, 3 of the 4 are around this value, the 4th on is at about 6200 uf, should this cap be replaced ?
Secondly I am replacing some Ceramic Caps @ 0.01 uf, now the ones on the board are a lot bigger than the same caps you get today, is it some new process that made these caps smaller or is their voltage rating higher than the standard one ?
These caps are also near the rectifier and the RMS output by the TF is 30 Volts.
On the parts sheet it says
Ceramic 0.01uf +100% -0%.
I do not understand the percantages, could some please explain what they mean ?
The same goes for other caps I am replacing,
Mylar 0.15uf +-10%,
The percentage rating here is more understandable since it seems like the tolerance rating of that cap but +100 - 0% is confusing.
Regards
Byron
