Hi all i just wondered what the main mechanism is that makes caps leak there guts,i assume mainly heat leading to pressure?,ie if i have a cap thats leaked in an smps what is better to replace it with to help stop ir happening again?,ie higher voltage rated cap,im not talking about low esr variants,i ssume heat is the main cause,ie bigger fans and better airflow?,do electrolytics exist with heatsinks?.
