Author Topic: Can you calculate power dissipation using only Volts and Resistance?  (Read 2300 times)
Offline cannontrodderTopic starter
Hi all!
I'm a beginner and working my way through The Art of Electronics 3rd edition and I'm glad I didn't just skim over the exercises because I'm getting a lot more insight into things. Although with this one, I'm coming up a little short...
The exercise is 1.6 which talks about how much power would be lost if you supplied New York City with a copper cable at 110 V.
Voltage = 110
Resistance of copper cable per foot is 5x10-8 Ohms
Amount of power used per day for NYC estimated at 1010 Watts
The exercise asks for:
1) "The power lost per foot from I2*R losses."
2) "Length of cable over which you will loose all 1010 watts"
The bit that has confused me is the power dissipation is P=IV and Ohm's law gives me the equivalents of P=I2R and P = V2/R. Other people have said to choose the formula that has the the values you already have so I picked P=V2/R which gives me P=2.4211 Watts. Supposedly that is the power lost per foot so dividing into 1010 shows me it would use all power after 0.413 feet. Seems wrong!
The question hints at I2*R losses so I went back and used that:
I = V/R = 2.29 Amps
..then P = I2*R = 2.4211 - AGAIN
Am I working this out correctly? It feels like I should be able to use the resistance over 1ft and the voltage to work out power dissipation but other answers dotted around the web seem to suggest I should be getting an answer around 24 feet. Am I correctly using P=V2/R to work out dissipation?
« Last Edit: August 13, 2015, 02:27:28 pm by cannontrodder »
Offline grumpydoc
Re: Can you calculate power dissipation using only Volts and Resistance?
« Reply #1 on: August 13, 2015, 02:20:06 pm »
Your mistake is that you don't have a drop of 110V every foot of cable.
Work out the current using voltage & power, and then put that into I2R to get the power loss per foot.
Oh, and learning how to use the superscript and subscript functions can help writing formulae.
Offline andtfoot
« Reply #2 on: August 13, 2015, 02:31:32 pm »
It's probably not the most efficient, but this is how I would initially attempt to work it out:
I think of the cable and the city is effectively 2 resistors in series creating a voltage divider. We need to isolate just the cable side to figure out #1.
First I divide the amount of power by the voltage to get the current through the system.
10E10 / 110 = 90,909,091 amps
The resistances, being in series, will have the same current through both. We can now either figure out the power lost in the cable with I^2*R.
90,909,091^2 * 5x10E-8 = 413,223,141 watts
We can then divide the 10E10 by the above, to get number of feet = 24.2
Offline grumpydoc
« Reply #3 on: August 13, 2015, 03:07:33 pm »
Or, to put it another way, you can't feed 1x1010 watts down a cable at 110V even if it does have only 50 nano ohms resistance per foot.
Which is what I suspect the exercise is trying to demonstrate.
« Reply #4 on: August 13, 2015, 03:27:05 pm »
Ok, the voltage drop over 1 foot is the obvious problem - ie, it doesn't drop 110V over 1 foot!!
So am I saying that the Voltage *does* drop at the point where the last of the power dissipates?
Anyway, I = P/V = 1010/110 = 9.09x107A
So now I think of the cable as lots of resistors in series, each 1 foot long so I can use the resistance of 1 foot to work out power dissipation:
P = I2R = 4.132 x 108W
And divide the total power loss by that to get the number of feet: 24.2 feet!!!
Thank you for your help grumpydoc, and andtfoot thanks for laying it out like that, I was still making silly maths mistakes once I had the right method  :-[
Grumpydoc, yes that seems to be the purpose of the exercise - it goes on to ask "what is the solution to this problem?". So if I=P/V and I increase the voltage, I can lower the current. Lower the current and the power dissipation specified by P=I2R will drop dramatically.
Thanks again!
Offline PSR B1257
« Reply #5 on: August 13, 2015, 04:50:42 pm »
This is true for the total length of the conductor.
But not for the cable, which consists of at least two conductors  ;)
In theory, there is no difference between theory and practice. But, in practice, there is.
