Hi All,
I have watched some videos where the presenter didn't use a dummy load for signal through the circuit. I can't remember correctly but I think it was a valve amp and the volume and gain was set 'just on', he did mention dummy loads but noted it was ok how it was setup for that purpose.
Is this setup only suitable for valve amp's or can this be used for solid state/mixed technology amp's?
As a safe alternative, if I build say just a 100 watt dummy load (for each channel) would that be ok to use with low gain/volume just for signal tracing? I'm thinking it would be ok as I'm not pushing too much 'power' around with low settings or will I need more power to test the signal path correctly?
The amp's I'm working on are usually around 450 rms watts per channel and some much greater but I'd like a simple setup just for signal tracing/testing for a complete audio path, not testing for clipping etc. I do intend on building a large dummy load at some point using something like water heaters in a drum but that's a bit cumbersome at the work bench for preliminary testing etc.
Are there any other alternative for this type of testing to narrow down to the problem area?
Thanks,
Mick
