Author Topic: What is use of constant current on differential amplifiers?  (Read 32240 times)
Offline materials_guy
Re: What is use of constant current on differential amplifiers?
« Reply #25 on: December 30, 2014, 03:45:56 pm »
v
« Last Edit: September 04, 2016, 08:04:50 pm by materials_guy »
Offline Bud
« Reply #26 on: December 30, 2014, 05:22:51 pm »
It's noteworthy that emitter degeneration must be avoided in applications where the TANH behavior is desirable: mixers and analog multipliers.
That is not always true and will depend on the maximum level of RF signal into the mixer that is required to be processed linearly. With no degeneration  it is limited to i believe 25mV or something. For higher input RF levels deveneration is used to maintain linearity.
Offline dannyf
« Reply #27 on: December 30, 2014, 06:13:00 pm »
I read that differential amplifiers "subtract" two input signals and amplify the difference.  Here, there's no difference to speak of so why is this referred to as a differential input stage?
The fact that there is no difference doesn't mean the input stage of that circuit isn't a difference amplifier -> The fact that at any given moment you aren't doing a good deed doesn't mean that you aren't a good person.
A (negative) feedback-based amplifier works by reproducing the output in a way to null the input. You can think of it as a tracking amplifier: say that you have a 1v input signal. The output thus the other input is at 0v. So the difference amplifier outputs a signal to increase the output to (0.5v). Now, your difference is only 0.5v. The difference amplifier outputs a signal to increase the output to 0.75v, ...... In the end, the output tracks the input. We think of it as "instantenous" when in fact there is an ever so tiny delay -> stability issues with feedback amplifiers.
Is it then correct to state that the collector current at Q102 is the output of the differential input stage and is a function of input voltage + feedback and this relationship has a TANH form?
The difference amplifier's output is its current on the collectors. That current, when the input stage is biased via a CCS, is solely the function of the difference between the two inputs.
That output is linear to the voltage difference, if you allow Vbe to be constant -> mostly true for small signal swings.
Offline dannyf
« Reply #28 on: December 30, 2014, 06:13:59 pm »
That's generally true for small signal bjts with sufficient emitter degeneration -> 99% of the amps out there.
« Reply #29 on: December 30, 2014, 09:47:06 pm »
v
« Last Edit: September 04, 2016, 08:06:46 pm by materials_guy »
