Author Topic: Phone's touchscreen goes awry when connected to a certain charger  (Read 2243 times)
Offline AlisonTopic starter
Hello everybody,
I recently bought this neat power station with four mains outlets and three USB that plugs right into a normal duplex wall plate.
I can charge my Nexus 7 off the USB ports just fine, but when I plug my Nexus 4 in the touchscreen goes slightly awry and randomly misses touches.
Could this be due to a high frequency crap on the DC output? Would I fix this by replacing the output capacitors with higher valued ones? Unfortunately I don't have an oscilloscope so I can't see how noisy the outputs are :(
Thanks!
Offline Rigby
  • Learning, very new at this. Righteous Asshole, too
Re: Phone's touchscreen goes awry when connected to a certain charger
« Reply #1 on: November 04, 2013, 12:32:17 am »
I've had that happen when the wattage isn't sufficient to both run the device and charge it.  The charge indicator would cycle on and off at about 1Hz.
Most USB chargers can deliver 5W of power, but few are rated for 10W, which some devices require.
I would check the ratings on the chargers that came with the devices and see if the new wall outlet thing can deliver the required power.
Offline echen1024
  • 15 yo Future EE
« Reply #2 on: November 04, 2013, 02:45:24 am »
No, simply not enough wattage.
I'm not saying we should kill all stupid people. I'm just saying that we should remove all product safety labels and let natural selection do its work.
https://www.youtube.com/user/echen1024
« Reply #3 on: November 04, 2013, 03:55:45 am »
Yep, my phone acts totally normal when it's the only thing plugged into the outletthingy's usb ports. I'm disappointed because my old USB outletthingy could charge my phone and tablet at the same time with no ill effects and was also rated at 2.1A. :(
I don't think it is worth to return the new outletthingy, I'll just live with it I guess.
Offline amyk
« Reply #4 on: November 04, 2013, 06:20:36 am »
Maybe it lies about its current rating...
Offline tan98010
« Reply #5 on: November 04, 2013, 06:37:25 am »
It is most likely there is a AC leakage, i faced this problem before, i solved the problem by grounding the negative at the DC to the mains ground.
Offline DavidDLC
« Reply #6 on: November 04, 2013, 08:32:19 am »
That is because it is a noisy charger
It happens with different chargers, different phones, that is why manufacturers recommend you to use approved chargers only.
David.
