Just a word about "being aware" of the risks of working with mains voltages.....
I've been "working with" mains voltages for more years than I care to admit, but this has been with fairly simple situations - mains wiring, switches, fuses, transformers and such. When there is a problem, these things can often be successfully diagnosed without power applied - and when power is applied, the measurements required are often simple and few.
Diagnosing an SMPS is more likely to be more involved. You will be making more measurements in a more confined space with more places for probes to slip.
I approach SMPS diagnosis with an order of magnitude greater care than "regular" mains circuitry. Not doing much SMPS troubleshooting will influence my caution, but it's still worth being more attentive.
