Author Topic: Drill Presses - Vice Selection  (Read 5953 times)
Offline T4PTopic starter
  • Country: sg
    • T4P
« on: August 28, 2012, 07:48:59 pm »
So i do have a F-clamp but i have been thinking, do i need a drill press vice? I have never used a drill press vice in the past but that made me think
Even so,
3 inches or 6 inches? I know 6 inches is pretty big but i need some input  :-\
Offline StubbornGreek
Re: Drill Presses - Vice Selection
« Reply #1 on: August 28, 2012, 08:11:24 pm »
Even so,
I hate drill press vices, I prefer to make a clamping table and attach to the table of the drill press. You can get rails and hold-downs at www.rockler.com - great place for woodworkers.
"The reward of a thing well done is to have it done"
-Ralph Waldo Emerson
Offline MikeK
« Reply #2 on: August 28, 2012, 09:33:04 pm »
I have a drill press vise, but I don't use it.  I just clamp things to the table with C-clamps or quick-clamps.
Offline Short Circuit
« Reply #3 on: August 28, 2012, 10:09:36 pm »
Have a few and use them quite frequently.
I believe they are 3" (old somewhat wiggly thing) and 4" (recent buy, reasonable sturdy).
3" is is a bit small, 4" seems quite right for typical electronics-related drilling.
Offline poorchava
  • Troll Cave Electronics!
« Reply #4 on: August 29, 2012, 06:36:54 am »
whatever you buy, get something of decent quality. If you go for cheap chinese stuff, you will regret it later. Those crappy ones are cast iron and generally droung only on the bottom, on the slides and the jaws, and the ground planes are not parallel/perpendicular to each other. They also have a fair amount of play on the slides which causes the moving jaw to go up when you tighten the vise.
I guess cheapest you can pay for a decent quality would be around $100-120.
  • Country: sg
    • T4P
« Reply #5 on: August 29, 2012, 08:20:35 am »
Well ... I'll try the cheapies first ( A 6" for 8 USD! )
After all 8 USD isn't much of a loss if it does turn out to be crappy
Offline codeboy2k
« Reply #6 on: September 03, 2012, 03:25:31 am »
That's just awful looking.
Don't spend 8 dollars on something that might fail  and not actually hold the work pieice, and cause a spinning piece of metal to slice your hand off.
Use C clamps or quik-clamps,  and wood blocks. With a drill press always go for safety first.
« Reply #7 on: September 03, 2012, 05:40:31 am »
A router (if you already own one, or table saw), some aluminum channel, mdf and homemade hold-downs will run you about $50 and you'll end up with something like this:
http://www.rockler.com/product.cfm?page=10163&site=ROCKLER
Offline G7PSK
  • It is hot until proved not.
« Reply #8 on: September 03, 2012, 07:34:23 am »
You using it for wood or Metal, if using it for metal get a really heavy one 8 or 10 inch that way when drilling small items there is no need to bolt it down it's own mass and just holding the handle is all that is needed. I drill up to 13 mm holes in steel this way as it is much quicker than bolting down.
  • Country: sg
    • T4P
« Reply #9 on: September 03, 2012, 05:24:21 pm »
@codeboy2k
Noted
@StubbornGreek
No router but table saw eventually  ;)
That's what i do with fat materials  :P
Offline MikeK
« Reply #10 on: September 03, 2012, 08:44:27 pm »
@codeboy2k, T4P
It might look scrawny, but that's actually a typical drill press vise.
If you want something beefier, I have one of these: http://www.sears.com/craftsman-3-in-drill-press-vise-cradle-angle/p-00924083000P.  Haven't used it on my 12" tabletop drill press, but used it plenty on my mini-mill.  Works great.
