Author Topic: Can a Powerbank be used to start a car?  (Read 48469 times)
Offline LateralNwTopic starter
« on: February 23, 2024, 11:12:46 pm »
Hi all, this is my first ever post.
This is purely an academic question.  I have no intention of doing it.  However I have a "friend" who thinks it can work and I would like to know if they could be right.
I have a background in electronics so I do understand some of the answers that may pop up.  eg No.
I want to get technical about it.
Lets say it is a 20Amp powerbank with the sole purpose when built to charge phones and possibly run low current devices.
Consider this unit as the example, 20000mAh Power Bank, ROMOSS Sense 6 Plus USB C Portable Charger with PD 18W QC 3.0
I'm sure there are many learned friends out there that will know the reason it can or can't be done.
I don't want the device to be modified but I guess it could be pulled apart to access the batteries.
Look forward to your feedback and help.
Cheers.
Offline Benta
Re: Can a Powerbank be used to start a car?
« Reply #1 on: February 23, 2024, 11:22:39 pm »
Well, if it can supply 300...500 A current while delivering at least 8 V for a few seconds, perhaps.
(I don't think so. I've seen so many hare-brained attemps on this that I'm yawning over this one).
The following users thanked this post: wraper, LateralNw
Online ataradov
    • Personal site
« Reply #2 on: February 23, 2024, 11:26:43 pm »
There are car starter power bank-like devices, but even those only work when connected in parallel with a battery. The battery may not have enough juice to start the car, but it must have some charge in it. The power bank just adds enough to start the car.
There is absolutely nothing you can do with a simple USB power bank like this.
Alex
The following users thanked this post: LateralNw
« Reply #3 on: February 23, 2024, 11:27:29 pm »
LOL
Thanks for the reply.
What about a trickle charge if PD was somehow enabled?
PD can supply 15-20 Volts but I am unsure if it could supply enough current.
I agree there is no way it can dump high current as I would expect the batteries will be a low discharge rate type.  Unlike say Radio controlled cars batteries.
Online brucehoult
« Reply #4 on: February 23, 2024, 11:38:41 pm »
There are two different kinds.
There are some with a battery inside, enough to start the car. I don't think they depend on the car battery itself at all, and you could even disconnect it, except that once the car is started you want its own batter to start charging.  I first saw these in Chicago in 2001, but they've probably around a lot longer. Everyone I knew in Chicago then and Moscow later had one in their car.
The much newer kind, maybe only in the last 5-10 years, doesn't have a battery. It's a giant capacitor. You charge it slowly from the "dead" battery for a few minutes, and then it releases the energy quickly to start the engine.
Offline Jwillis
« Reply #5 on: February 23, 2024, 11:45:45 pm »
Your power bank is rated for 5V. An average car battery is 12V. An average car wouldn't crank over with 10V. So the amount of current available is irrelevant. You could have a million  Amps and that car still would not crank at 5V.
Offline mawyatt
« Reply #6 on: February 23, 2024, 11:47:07 pm »
Remember as a kid when neighbor was studying transistors in trade school. He got all excited about using a transistor when he discovered they had current gain of 100 or more and was going to revolutionize the world by use a couple D cells and transistor to replace the standard car lead acid battery :palm:
Best,
~Wyatt Labs by Mike~
The following users thanked this post: RJSV
Offline Benta
« Reply #7 on: February 23, 2024, 11:50:35 pm »
Youtube much?
"Never give a sucker an even break."
W.C. Fields.
Offline Jwillis
« Reply #8 on: February 23, 2024, 11:58:22 pm »
Youtube much?
W.C. Fields.
Far to many people trying to get an education from the University of You Tube.
Online brucehoult
« Reply #9 on: February 24, 2024, 12:25:00 am »
Youtube much?
W.C. Fields.
What youtube?  These products are seen in reputable stores.
https://www.jaycar.co.nz/capacitor-based-12v-300a-jump-starter/p/MB3765
Possibly they are incorrectly described. I don't know. I haven't bought one and certainly haven't disassembled one. But the descriptions are very clear.
Offline Jwillis
« Reply #10 on: February 24, 2024, 12:39:18 am »
Youtube much?
W.C. Fields.
Sure. I've used those myself. But that's comparing apples with oranges. The Opening post is describing a 5V USB power pack not a 12V battery booster for cars.
Online ataradov
    • Personal site
« Reply #11 on: February 24, 2024, 12:39:33 am »
I have a battery-based very generic one, that is branded under 100 different names. And at least in the manual it says that the battery of any sort is needed. No idea if it tests for it.
From the feeling - I don't know how well it will start the car on its own. Even with a semi-dead battery it struggles.
But overall, I would say it is worth it, and it saved me during pandemic when the car was sitting for a long time.
I do worry about that huge battery pack sitting around that is exposed to high current draw. I was not aware of the capacitor ones, I will need to look into that.
Alex
Offline Benta
« Reply #12 on: February 24, 2024, 12:46:23 am »
That thingy is a supercap bank that needs to be charged from another fully charged battery. In short: a replacement for jumper cables.
Your "magic revival of a flet battery" is not in there.
"Reputable stores?" More like "very selective customer information" stores.
Youtube much?
Online brucehoult
« Reply #13 on: February 24, 2024, 02:32:13 am »
Youtube much?
They 100% definitely say they can start a car with low battery after charging it from the *same* battery.
Not from a 100% dead one, obviously. Just one that can't crank the engine. As a rough guide, I'd expect that if the battery can still run the dashboard lights, radio -- certainly if the headlights work -- then there is absolutely no reason why charging the device at 10A for 60 seconds can't then supply 200A for two or three seconds.
Online brucehoult
« Reply #14 on: February 24, 2024, 02:33:04 am »
Obviously.
Offline ejeffrey
« Reply #15 on: February 24, 2024, 02:52:41 am »
To answer the original question: no you cannot start a car with an unmodified standard 5V USB power bank regardless of size.  But the batteries inside it might be able to if set up properly.  That's essentially what the lithium ion jumpstart batteries are and they can and do supply the hundreds of amps needed to start a car, even with a completely dead battery.
Offline amyk
« Reply #16 on: February 24, 2024, 03:16:44 am »
Some of them definitely can, but I personally wouldn't want a lion battery with that much energy in my car.
Online brucehoult
« Reply #17 on: February 24, 2024, 03:21:12 am »
300A for 3 seconds is 250 mAh, which is 20% or 25% of what a AAA holds. (Obviously you'd need 10 AAAs to get sufficient voltage)
Offline MrAl
« Reply #18 on: February 24, 2024, 03:27:40 am »
Cheers.
Hi there,
There are a couple different scenarios to look into here.
First, it will not start the car if there is no regular car battery in the car.  The starter requires way too much current for those little power banks.
However it could start a car if the regular car battery is still in the car and the battery is not bad, just depleted somewhat.  If the battery reads below 8 volts it is probably bad, but it might perk up with a charger.  So we will have to assume the battery in the car is not bad.
In theory, if the car can start within 4 seconds and the starter draws 600 amps, then the maximum charge would be 2400 ampere seconds, which is only 2/3 ampere hours or in decimal about 0.67 ampere hours.
The power bank shown there is said to be 20000mAh which is 20 ampere hours, so at first it may sound like there is no doubt that it could start the car if the power bank is connected to the battery somehow.  There is just a little more to it though, and that is the voltage.  The voltage output of the power bank without modifications or an extra QC circuit 'fooler' will be 5 volts, and to charge the battery it will have to be stepped up to around 14 volts, and due to inefficiencies, we could say it is 15 volts for now.  Since we have to step 5 volts up to 15 volts that means the current will step down from whatever the power bank can put out by a factor of 3, which means if it was rated for 4.5 amps out at 5 volts we could get roughly 1.5 amps at around 14 volts.  It may be a little less, but from experience I know you can charge a car battery with 1 amp as long as the battery is not too old and is not sitting at 0 volts.
To get from 5v to 14 volts, we would use a boost converter.  That would take an input of 5v and convert it to 14 volts.  That would then start to charge the car battery.  If the current is 1 amp and we know we need 0.67 ampere hours, that means it has to charge for at least two thirds of an hour, which is 40 minutes.  If the current comes up higher then that's even better, but there are some power banks that only put out 1.5 amps at 5 volts.  That would mean that we would only get about 1/2 ampere out of it, which is very small for a car battery although it may still charge if it is not too old.  It will take at least twice as long though, like 80 minutes, in theory.
So that's about the size of it as theory would predict.  The only other possibility then is to use a QC fooler circuit that allows you to set the output voltage higher, but you may not be able to get the right output voltage for charging without the power bank shutting down.  That means it would depend highly on the power bank being used.  Using a boost converter with adjustable output though means we can adjust the voltage (and thus the current) and that means the power bank should not shut down.  It may be necessary to add a small series resistor though in series with the output of the boost converter (or power bank).
So theory says it can be done, all that would be needed to do is a few experiments.  When I worked with a solar panel and car battery I found that it kept the battery charged very well even with a current of 1 amp for part of the day.  In the case of charging with a power bank, I would opt for one that can allow us to put out at least that 1 amp at 14 volts using a boost circuit.  To get that, it would have to put out 5 volts at 3 amps minimum, which means a charge time of about 40 minutes.  If we do not let it go for the full time and try to start the car say after 20 minutes, the car may actually start, but if the car does not start then we have to start all over again and wait that 40 minutes anyway, and since the first try we stopped at 20 minutes, that would mean we would have spent an hour trying to start the car instead of 40 minutes.
Offline radiolistener
  • Country: ua
« Reply #19 on: February 24, 2024, 09:20:34 am »
Vehicle starter requires at least 200-300 Amps in summer and up to 600-800 Amps in winter.
The power bank that you show is unable to provide such current.
You're needs to search power bank which can provide at least 12*300 = 3600 Watt power (3600000 mW)
Offline Terry Bites
« Reply #20 on: February 24, 2024, 09:53:24 am »
Nah, but you can jumpsart your motor with an 18V drill battery.
True.
Offline Jwillis
« Reply #21 on: February 24, 2024, 10:09:59 am »
Car batteries are rated with CCA (Cold Cranking Amps) at 0oC.A small 12V car battery is around 300 - 400CCA. Conversion to AH is CCA/7.25=AH. So a 300 CCA battery would have A little over 41AH at 12V or 492Wh. A Lead acid battery is considered to have 0% capacity at 11.59V. This means that a load will drop the voltage to 0V simply because theirs not enough amps.
To fully charge a 12V battery you need at least 13 -14 volts. But its possible to partially charge at 12V.
That power pack is 5V at 20A or 100Wh. You would have to use a boost converter to get 12V. So 100Wh divided by 12 give you the Ah of you pack at 12V. So your pack at 12V only has 8.3Ah. That's not including the losses of the converter.
8Ah is 20% of the lead acid 41Ah battery capacity. That would raise the capacity of a 300CCA car battery 20% Or to 11.76V. That a gain in voltage of 170mV. This is not taking into account any losses from converter and a Lithium battery voltage drops out fast after 80% discharge.
« Last Edit: February 24, 2024, 10:14:27 am by Jwillis »
Offline BeBuLamar
« Reply #22 on: February 24, 2024, 12:42:49 pm »
The car's alternator generates more than enough electricity for the car when the engine is running. The battery is only needed to start the engine and if the car can be stated with the little power bank why do they put such a large battery in the car?
Offline shapirus
  • Country: ua
« Reply #23 on: February 24, 2024, 01:05:12 pm »
This is legit. Supercap based jump starters definitely work.
The amount of energy required to start an engine is very -- surprisingly -- low. Even a half-dead car battery contains more than enough of it. But the problem is that this energy must be released in a very short time, and this is what a depleted or degraded lead-acid car battery is not capable of. A sufficiently large supercap bank, OTOH, can do it, and with a proper charging circuit it can be charged from any low-power source, including a powerbank, that would never be able to start an engine on its own.
Offline RoGeorge
« Reply #24 on: February 24, 2024, 01:17:04 pm »
Yes it can.
Assuming enough energy is available in that powerbank, and all that energy can be stored then eventually pushed at a high enough rate (at high enough power), then yes, it can do whatever the job is, including starting a car.  There are Li rechargeable power packs already for this purpose alone, to start a car that has a dead/discharged/not-powerful-e
nough-in-cold-weather battery.
