Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Help with Microchip Datasheet
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Help with Microchip Datasheet (Read 1816 times)
Luchik
Newbie
Country:
on:
August 30, 2016, 09:53:34 am »
I am trying to understand the VSS and VDD pins connection in this Microchip datasheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/40001825A.pdf
I am using
44-QFN Package
, so i found the pin allocation map for this package on Page 7:
according to this picture, VDD are pins: 7,8,29,28; and VSS are: 6, 30, 31.
I also found this pin allocation table on page 13:
Pins 7 and 29 are not shown in this table!
can I trust the allocation map to be true with both pins (7,29) being VDD?
Logged
amyk
Super Contributor
Re: Help with Microchip Datasheet
Reply #1 on:
August 30, 2016, 10:31:11 am »
That's a
preliminary
datasheet... some errors are to be expected. But the fact that two packages with the same number of pins have a mostly the same but slightly different pinout is a big
I'd choose a more mature product unless you have a compelling reason to use it. This one is far too new.
Logged
EEVblog
Administrator
Country:
Reply #2 on:
August 30, 2016, 10:35:30 am »
I'd trust the pinout diagram over the table.
As mentioned, yeas, a preliminary datasheet, bound to be some copy'n'paste errors. Report it.
Logged
Luchik
stj
Super Contributor
Country:
Reply #3 on:
August 30, 2016, 11:11:40 am »
trust neither,
email microchip and point out the error - get them to clarify it.
Logged
Kjelt
Super Contributor
Country:
Reply #4 on:
August 30, 2016, 12:08:19 pm »
Mistake has been in their datasheet since 2014:
http://www.mouser.com/pdfdocs/40001768A.pdf
Logged
Kjelt
Super Contributor
Country:
Reply #5 on:
August 30, 2016, 12:10:54 pm »
If you have the chip measure the ohms resistance between the Vdd pins and the Vss pins , they should be close to zero ohms, that would give some confidence.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
