Author Topic: DSE q1770 PSU  (Read 3567 times)
Offline ChopsticksTopic starter
DSE q1770 PSU
« on: June 17, 2012, 02:13:55 am »
I was going past dick smiths yesterday and on a whim i went it to see if they had any of those $49 bench psu's left and sure enough there was one sitting on the back of a top shelf gathering dust. fantastic i thought so i bought it and took it home, worth nothing there may still be some of these units floating around if anyones keen to go looking.
Anyhow the only issue i have with it so far it that the voltage dial is extremely sensitive as such say im setting it to 5vdc just the slightest movement can increase/decrease that voltage very quickly, so i was wondering if theres a way to somehow change the pot value etc so that its easier to select a voltage, in a perfect world it would have had a rotary encoder in it though i doubt thats a possible mod as im sure the current circuit relies directly on the current pot to adjust resistance etc...
Anyone got one of these units and have any ideas?
Offline Rerouter
Re: DSE q1770 PSU
« Reply #1 on: June 17, 2012, 02:15:21 am »
rip it open, find out its value and throw money at a 5 or 10 turn potentiometer,
Re: DSE q1770 PSU
« Reply #2 on: June 17, 2012, 02:40:24 am »
i dont know why i didnt think of multi-turn pots...
thanks mate  :)
Offline BradC
Re: DSE q1770 PSU
« Reply #3 on: August 11, 2017, 09:02:21 am »
Holy thread revival batman.
I have had one of these power supplies for years now (and for the record I love it). The voltage pot is a 50K linear.
I just finished replacing it with a 5 turn wirewound. RS Part No 460-1950. Because the pot is 22mm you need to remove the top PCB standoff adj the voltage pot to get it to fit. I made a steel washer to sit behind the panel and modified the existing voltage knob to fit. It's not as pretty as it was, but 6V/turn is easier to get control of than 30V across 240 degrees.
Offline Muttley Snickers
  • Cursed: 679 times
Re: DSE q1770 PSU
« Reply #4 on: August 11, 2017, 09:58:01 am »
Forty bucks a pot  :o,  I agree that other than the shit house potentiometers Manson used in these units they are actually not a bad little supply and do the job for most of the lighter tasks, I have two of them and they are probably my most frequently used supplies and have been for many years. I found when the original controls start to fail just the act of touching the outside case of the supply would cause the output to vary dramatically, I was hunting a ten turn 50k for these without any luck but that five turn 50k pot should do nicely.
Offline BradC
Re: DSE q1770 PSU
« Reply #5 on: August 13, 2017, 05:01:02 am »
I gave up buying cheap E-bay components years ago. Yeah its 40 bucks, but I know it's legit, quality and reliable. Free delivery and it was on my door step in 5 days.
I buy most of my stuff through RS these days unless it's not critical where I get it from Altronics.
The 5 turn gives me vaguely 6V/turn and is considerably better for fine control than the technique I developed using my fingernail to knock the serrations on the voltage pot to get fine(ish) control.
Offline wilfred
Re: DSE q1770 PSU
« Reply #6 on: August 13, 2017, 05:55:22 am »
I only paid $49 for mine. Putting a $40 pot in it seems like over capitalising.
