Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
How to test negative power rail with electronic load
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How to test negative power rail with electronic load (Read 1394 times)
belzrebuth
Frequent Contributor
Country:
on:
August 04, 2018, 09:20:31 am »
Hi all,
I've got a XHDZ-FZ-2D electronic load module from eBay
https://www.ebay.com/itm/DC-1V-100V-Constant-Current-Source-Electronic-Load-Board-50W-Max-6A-Power-Tester-/232419643651
and wondering if I can use it to with a negative voltage.
The DUT is floating so can I just reverse the leads on the load input terminals?
The schematic for the module are here:
https://drive.google.com/file/d/0B4zALdueXAxdcm1jSWt6Tm9TZXc/view
Last Edit: August 04, 2018, 09:23:21 am by belzrebuth
Logged
Zero999
Super Contributor
Country:
0999
Re: How to test negative power rail with electronic load
Reply #1 on:
August 04, 2018, 01:49:59 pm »
Yes, it can be used to test a negative supply.
No, don't reverse the terminals. Connect the positive to the 0V rail and the negative to the negative power rail.
Logged
belzrebuth
Country:
Reply #2 on:
August 04, 2018, 04:13:07 pm »
Thanks!
Logged
Mechatrommer
Super Contributor
Country:
reassessing directives...
Reply #3 on:
August 04, 2018, 05:36:48 pm »
dont forget to add heatsink to the fleabay module, it can burn out pretty quick for higher load..
Logged
belzrebuth
Country:
Reply #4 on:
August 04, 2018, 05:42:42 pm »
I have it for quite some time actually; it's in an enclosure with a big heatsink attached to it so no worries.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
