Let me explain what I'm trying to do.
The car is a 2012 Honda Civic, which has the infamous Honda two-stage charging system. In normal daytime driving, the alternator puts out 12.3-12.4V, which only charges the battery about 60%. That's still enough to start the car. But if the headlights are on, or any other big current drain, the alternator cranks up to 14.4V.
I have a voltmeter installed in the cigarette lighter socket, so I can see what the alternator is doing. Normally, I always drive with the headlights on so I can keep the battery fully charged. But recently, I've noticed that it stays at 14.4V all the time now - whether the headlights are on or not. So that's a malfunction of some kind.
So as I see it there are two possibilities. The first is that the computer is sensing the battery voltage as being lower than it really is, or is sensing the total system current as higher than it really is, but nothing is really wrong. The second possibility is that I have a major current leak somewhere when the ignition is on which is equivalent to the headlights being on. If that's the case, I'd like to fix it.
So my plan is to turn on the ignition, but NOT start the car, and measure the current flowing from the battery with the clamp meter. With no lights on and nothing running, it would just be what the computer draws, plus maybe some solenoids, so maybe a few hundred millamps. But if there's a major current leak, it would be a lot more.
Since posting it occurred to me that it might be possible to do this test by just measuring how much the battery voltage drops when the ignition switch is on but the car isn't running, using my regular meter. I could even try turning on the headlights to get an idea of how big a drop that causes. But the voltage drop may not give me enough information to make the call. I don't know what the drop would normally be if there's no current leak, although maybe someone here could tell me that.
I'd just hate to spend $50 on a meter I might use exactly once.
The daytime running lights may mess this up if they come on when the ignition is switehed on. So I may need to figure out a way to disable them. There may be a fuse for that.
